Popular Talk Forums Is Agreat Online Business Platform
Peter Mwaura Mutiti
Mobile: +254-727-636-872
(whats-app) Mobile +254-723-024-871
http://web.facebook.com/populartalkforums
ACNE AND OMEGA 3 SEAL OIL
Post by pmmutiti on Tue Feb 17, 2009 6:57 pm
Acne Fact and Fiction! Do Stress, Facials and Concealer's Help to Promote or Reduce Acne Breakouts?
What is Acne? People have differing opinions as to what acne really is. So, what exactly is acne? Do a couple of occasional but recurring zits qualify as a case of acne or do you have to have a lot of zits?
Believe it or not, the answer is that occasional pimples or zits do not constitute a true case of acne. Although zits do seem to have the ability to appear almost instantaneously and at the most inopportune times like picture day, prom night, spelling bees, sporting events, dates, and special award ceremonies, they are not a true acne outbreak.
The dictionary defines acne as "an inflammatory disease of the sebaceous glands, characterized by comedones and pimples, especially on the face, back, chest, and, in severe cases, by cysts and nodules resulting in scarring."
The anatomical definition of sebaceous glands is: "small subcutaneous glands usually connected with hair follicles. The follicles secrete an oily semi-fluid matter, composed in great part of fat, which softens and lubricates the hair and skin."
Real acne outbreaks are actually a disease of the skin. However, the great news is that acne is treatable. Although it can be very embarrassing, cause great emotional distress, and lower your personal self-esteem for a period of time, acne is not fatal.
There are new and effective treatments being sought by researchers and great advances have been made in the treatment of acne in the last few years. Years ago, when a person had acne, they were pretty much stuck with the problem. There were very few treatments available and the medical profession didn't even consider acne a disease.
It was long thought that acne was the direct result of a diet that was too high in fat and/or sweets. That is no longer the case. Acne is most often associated with puberty and the onset of pre-teen and teenage years but it can and does develop in adults as well. When acne does finally heal, there can be permanent scars left (from picking and popping) that are unsightly and cause patients to suffer long term emotional distress and low self- esteem.
New and very effective skin resurfacing treatments have been developed over the last several years that have, if not completely removed acne scars, at least diminished their appearance and severity.
Acne Fact or Fiction:
You can hear a lot of tall tales about acne today, so let's take a look at the fact or fiction of acne. It is always better to be well armed with factual information so that you don't get fooled by the fictional facts that surround acne.
Fictional Fact #1: Acne is caused by a lack of sexual activity.
Factual Fact: Acne and sexual activity are two entirely separate issues. One has no bearing on the other. Hormones secreted during puberty and young adulthood does have a bearing on acne. They also have a bearing on sexual arousal and activity. However, acne has no bearing on sexual activity nor does sexual activity have any bearing on acne.
Fictional Fact #2: People have acne because they are dirty.
Factual Fact: Dirt has no part in acne. Dirt is dirt. Acne is acne. One has nothing to do with the other. Acne is a build up of oil, dead skin cells, and bacteria. Dirt isn't involved. Keeping the face clean can and will help to prevent clogged pores but dirt does not cause acne.
Fictional Fact #3: Dermatologists can cure acne.
Factual Fact: Dermatologists can TREAT acne. They can help to alleviate the symptoms and help to clear up the pimples, black-heads, and white heads. They can prescribe antibiotics and topical ointments, lotions, and creams that will help but there is no cure at this time for acne.
Fictional Fact #4: Acne is simply a skin problem.
Factual Fact: It's true that acne affects the skin but it can also affect the way a person sees himself or herself. Acne and the scarring it can leave behind may cause a sufferer to become depressed and develop low self-esteem, both of which can lead to larger and more complex life socialization problems. Acne sufferers need the loving support and reassurance from their family and friends.
Acne and Stress:
Can stress actually cause acne? There is ample evidence available to suggest that stress can most assuredly cause an acne breakout or make an existing breakout worse. Our bodies are highly developed chemical laboratories that produce all sorts of stuff.
At puberty, our body begins to produce an abundance of male hormones and this happens in both boys and girls. This overproduction of male hormones can happen at other times in life besides puberty; for example, when a girl or woman starting or stops taking birth control pills.
These male hormones cause the bodies sebaceous glands to shift into overdrive and begin producing sebum. The sebum then travels up hair follicles, clogs the pores and begins the acne development cycle. However, male hormones are not the only cause for the sebaceous glands to begin producing an overabundance of sebum. When we become extremely stressed or overly emotional, our bodies react by causing the adrenal glands to produce a substance known as Cortisol, which is released directly into the bloodstream. Then the chemical chain reaction continues as the sebaceous glands release sebum, the sebum travels up the same hair follicles, clogs the pores and acne develops.
The physical changes in the body can cause exactly the same chemical chain reaction as the emotional changes in the mind. The mind/body connection is very real. Maybe some of it really IS in your head. If that's the case, there is help available to help people deal with the acne that is caused by stress. Reducing stress will just naturally reduce sebum production by the sebaceous glands and reducing sebum production will help to alleviate an acne breakout. Therefore, when you learn to reduce and control you stress levels, this part of the chemical chain reaction is minimized.
It really it isn't any different than restoring a hormonal balance to your body that reduces sebum production. So, in the final analysis, both factors that cause excessive sebum production should be addressed. Solving one problem might help; however, solving both problems could eliminate acne altogether.
Peter Mwaura M
Ariix Africa Team & Business Leader
Mobile+ WhatsApp +254-723-024-871
http://ariixafricagroup.exploreariix.com
E-mail:pytcom@gmail.com
pmmutiti
Forum Director
Forum Director
Number of posts : 121
Kenya : Nairobi
http://taslykenya.blogspot.com : http://vemmafrica.blogspot.com
Peter Mwaura Mutiti : Teaching old blood cells new tricks:
When you hear someone mention circulation you probably think of the heart and major arteries—and for good reason. Circulatory disorders such as hypertension (high blood pressure) and atherosclerosis (hardening of the arteries) are major risk factors for heart disease, heart attacks, and stroke.
But there’s more to it than that. With all the attention on the heart and arteries, it’s easy to overlook serious health problems affecting the smallest components of the circulatory system—microscopic blood vessels called microcapillaries, where the critical exchange of oxygen and nutrients actually takes place. If blood isn’t flowing through this web properly, it can trigger all sorts of health problems, many of which may not seem related to circulation at all.
A number of factors contribute to poor circulation as we age. Arteries and veins become stiff and congested as cholesterol and calcium plaques accumulate and restrict blood flow. Spasms in the smooth muscles surrounding the circulatory arteries and veins can also choke off circulation. These same processes also occur in our microcapillaries, reducing microcirculation and impairing the critical exchange of nutrients and gases in tissues and major organs.
This problem only gets worse as we get older because of changes in the composition and structure of blood cells. As you reach middle age, the blood starts to thicken and congeal as platelets and blood proteins make cells sticky. Plus, the spleen—the organ that removes old, damaged blood cells from circulation—begins to slow down with age, which means new, healthy blood cells are replaced at a sharply reduced rate. And to make matters even worse, as blood cells age, they become stiff and no longer appear round and evenly shaped. This makes it harder for them to pass smoothly through the capillaries. In fact, the angular, jagged shape of the old cells can damage the fragile microcapillaries even further.
Eventually, these age-related changes take their toll on the microcapillaries, reducing circulation to the tissues and blocking the flow of nutrients and oxygen. Removal of carbon dioxide and other metabolic waste products is also hindered. This leads to a slow buildup of metabolic garbage that can gradually bury the cells in their own waste products. In time, the cells, poisoned by their own metabolic byproducts, begin to waste away and ultimately cease to function altogether.
The combined effect of poor circulation and old blood contributes to a host of symptoms, including deep fatigue, fuzzy thinking, frequent infections, and lowered sex drive—all conditions usually considered just “normal parts of aging.”
If circulation doesn’t improve, it can lead to more serious conditions, such as high blood pressure, heart attack, stroke, diabetes, and arthritis. But giving your body a fresh supply of healthy blood may target all of these problems and more.
Ann Njoki : Forum assistant
Registration date : 2008-01-10
View user profile http://my.vcita.com/pmmutiti
